Jun 29, 2023 1:35 PM UTC
Booleans don't seem to work inside components
I have run into a bug / limitation on Boolean variables.
I created a button component with an active and a disabled state. The property to switch between them is a true / false Boolean.
I set a boolean variable #decementActive
This is used in a layout with buttons, one that increments a count upward, and another that increments down. The boolean property is tied to the #decrmentActive variable for the button that decrements.
It is set to false by default, meaning the decrement button is disabled state.
When the user clicks the increment button, it sets #decrmentActive to true and the decrement button becomes active. So far, so good.
If I convert this into a component, the boolean no longer works on this or any other button or anything else. Other assigned variables — color, numbers, strings — are fine. It strips booleans from the button and I cannot reattach them.
Is this a bug? A limitation? Am I missing something?
JacekDynski
Dec 27, 2024 12:44 PM UTC
My solution to this annoying issue was to remove component inner state from interactions, and repeat it in the interaction that sets variable.
Before:
After:
See - “Change to” action was part of component inner state.
This is pain in the a**, but I could not find other working solution.
