Amadeusz_Wasik
Boolean property false by default for instance but keep it visible in master component
I would like to update a button component…so you know, thousands of instances are already in use across many design files. I would like to add an extra element but I would rather like to avoid turning it off (by boolean switch) on 99.99% of instances by hand. At the same time, would be great to keep it visible on the master component in a library so frontends will easily understand all possible scenarios for the component.
I was thinking about an example on a side with all elements visible but not every size is the same - different variants of the same sub-element (i.e. smaller or simpler for smaller sizes). It would lead to basically duplicating the whole thing…
Does anyone know if it is somehow possible? By trick or plugin…dunno.
Hi @Amadeusz_Wasik, Thanks for contacting us regarding this matter.
It seems that you will have to manually select each instance and set the new element toggle to off.
I have done some research and came across plugins that could assist you in selecting multiple instances at once:
While it may not completely meet your requirements, it might help minimize the need for manual work. Feel free to explore on your own: https://www.figma.com/community.
If anyone in our community has any other solutions for this issue, please feel free to contribute.
Thanks again for reaching out!
