Hi there! I am kind a newbie so please be gentle 🙂
I want to create an autolayout button with complex background, it is not a simple rectangle as you see below:
And i simply can’t do it with this shape, I can’t place it as a background under the label
You can’t do that because that shape is a simple vector object. And it will look very bad if you stretch it. I recommend creating two separate sides to create the shape and placing the rectangular auto layout in the middle. I just added an example into this file I created and you can find other useful examples there too:
Easy: instead of coloring the central rectangle autolayout, put two horizontal lines in it. And turn sides into strokes, removing two vertical lines from them.
