Jesse_Wallace
Autolayout bug in nested components
  • March 17, 2022
  • 21 replies
  • 5976 views
I noticed a bug that has recently appeared sometime in the past two weeks dealing with autolayout and nested components.
Our team uses master components so that we can push style changes to all variants quickly. It works great and helps keep things tidy. The only issue with this is that if you want a full-width component (for instance, a button you want to expand to the size of the mobile screen), you would normally have to take these steps:
  1. Drag a variant instance onto the frame
  2. Double click to go from the variant to the master button frame
  3. Change Resizing from “Hug Contents” to “Fill Container”
  4. Adjust the width of button width as necessary
This has historically worked but now whenever these actions are done, trying to set any Resizing option automatically chooses Fixed Width. This breaks resizing nested components.
You can view this process in the video below. I created a new master button and a small variant set, and then show how the base button width responds correct, but the variant button instances cannot be changed to a different resizing option.
Autolayout Resizing Issue
This effectively breaks many components in our design system, which is probably also breaking other users that employ similar component creating techniques.
Again, this only started happening recently and seems to be a bug in the software.
Is there a fix in the works on this?
Brent_Riddell1
March 18, 2022
Experiencing the exact same issues with my libraries and components rendering most of them broken/useless now (I filed a bug ticket with Figma already). Also hoping for a fix soon as it does seem like a particularly nasty bug 😬
I have found a temporary fix (that long term might cause more issues) :
  • select the nested component within the main component that won’t respond to auto-layout overrides anymore (sometimes this means selecting multiple nested instances and performing the steps below)
  • choose any different auto-layout prop than it currently is and then switch back to what you want it to be by default
  • you’re effectively creating an override state here within the main component on the nested component that figma can recognize and respond to again.
  • now your instances auto-layout properties will be able to be overridden again as it worked before
  • but be careful as you will need to do this trick on both axes (width and height) if you want those to be able to be overridden later and this can create problems with children as sometimes this forces them into different auto-layout modes such as fixed (you can reset/fix those too of course, but these are also then treated as overrides as well … so you just need to be aware that causes problems too potentially)
  • this also means that your original main components auto-layout props are no longer connected to your nested instances anymore as they have been overridden, which breaks a lot of utility of using nested components in the first place and its pretty time consuming / impossible on very complex large libraries to do this without breaking a lot of stuff.
Update: recorded a video demo of the above method but can’t post it because i’m not trusted enough to post links (support is looking into it, hopefully can post it soon)
Brent_Riddell1
March 18, 2022
Here is a short video showing how to do the ‘fix’ outlined above:
Horia
March 18, 2022
I’m also getting this bug and this in making a lot of components in my Design System unworkable. I am now forced to detach instances which is 💔. Hope this gets addressed ASAP.
Brooks_Solveig
I also use master components in the same way as OP. My design system is also being impacted by this bug. Really frustrating.
At least someone else is experiencing it, because I thought I was going crazy for a bit there.
Brent_Riddell1
March 19, 2022
Got an update on my support ticket from figma and they have identified the issue and are working on a fix! 🎉
Marc13
March 22, 2022
Have they provided any ETA?
I’ve been wrecking my brain for the past few hours trying to figure out what was wrong. and unfortunately its still not fixed 😦
Prazak_Dawid
March 22, 2022
I’m also being affected by the issue.
Erik_Goens1
I just ran into this issue as well. Is there any traction on a resolution?
Jesse_Wallace
I initially heard from support with a solution to try, but it didn’t remedy the issue. I’m currently in process of being escalated to the engineering team, so no fix yet.
Marc13
March 22, 2022
This sounds like a bug that was reported recently where attempting to change the constraints seems to not behave as expected.
I’ll be noting your encounter on this bug report. I’m afraid there aren’t any workarounds for this, but it appears a fix will be released soon as our team has been investigating this.
I recommend testing this once again by the end of this week — If the issue persists, please feel free to reach out to us and we’ll follow up with engineering.
Thanks for your patience as we work this through!
