Greg23
Apr 16, 2024 12:42 AM UTC
Auto layout no longer functioning as normal?
Hi all,
Did Figma change the way auto layout operates?
I always used to able to highlight 2 (or more) auto layout frames, and then add auto layout to that selection, but am no longer able to do so.
Here’s a loom video illustrating precisely what I mean: Problems with Auto Layout
Any insight would be greatly appreciated, because this is driving me crazy.
Thanks!
Yuls_Walters
Jul 25, 2024 5:09 PM UTC
  1. When I add a new element, everything moves to the top, instead of keeping the alignment I settled previously. In this example (image) everything supposed to be aligned to the top-right, so when I add a new element, the rest of the elements should move down, not up… Loos at the red line in image 1 I added to identify the initial position of the frame.
I hope I explained myself better.
Thanks for your help @Gleb !
Yuls_Walters
Yes you are right sorry. I’ve been too frustrated with it.
Here are the problems I’m experiencing:
  1. The properties from the frames are not working for me. For example, I apply the auto layout to a frame, and I set the W and H as “Hug”, but when I add another element, the frame doesn’t hug the elements and doesn’t grow.
  2. I set the alignment on the auto layout to the top-right, but in the frame, it is aligned to the top-left. Here is an image:
Continue in the next message…
Power Member
Jul 25, 2024 5:19 PM UTC
As I suspected, the frame is rotated (flipped upside down).
Yuls_Walters
Jul 26, 2024 8:26 AM UTC
😱 Ok, now I’m clueless on how that happened. But I’m happy you found it! Thanks again for your help! 🙃
