Mar 26, 2024 10:43 AM UTC
API call results in an empty data response (202 Statuscode)
Hi together we are facing a strange behaviour regarding the Figma API Endpoint /v1/images
We are fetching some images but sometimes it happens that we get an API response with an empty data field, but no additional error like “to many request” or similar.
Is there any know issue or limitation?
jefflee
jeffleeSolution
Mar 26, 2024 8:39 PM UTC
Hey folks, Jeff from Figma here. We appreciate everyone’s patience on this issue and sincerely apologize for the disruption.
First, the details: we had a misconfiguration in our anti-automation protection. This was in effect from March 25 5:50PM Pacific to March 26 8:50AM Pacific, and affected about 0.5% of our REST API traffic. As others have observed in this thread, if you hit this issue, you’d get a 202 status code with an empty response body. Definitely not great!
We’re working on trying to prevent this thing from happening again. More than that, we’re also not happy with how long it took us to get to a solution. We had some early metrics that didn’t accurately convey the scope of the issue, and we’re working on improving our response time.
Thanks again for everyone bearing with us.
Mar 26, 2024 10:57 AM UTC
Update: Looks like we get an Response with status code 202. How is the best way to resolve this status code?
The 202 (Accepted) status code indicates that the request has been accepted for processing, but the processing has not been completed.
For me its out of context what this status code means in combination of the called endpoint.
Alexander49
Mar 26, 2024 11:25 AM UTC
We’ve also been struggling with this behavior for a couple of hours so far.
We took a look at the headers sent by the server:
'server' => { name: 'Server', value: 'CloudFront' },
    'date' => { name: 'Date', value: 'Tue, 26 Mar 2024 11:12:35 GMT' },
    'content-length' => { name: 'Content-Length', value: '0' },
    'connection' => { name: 'Connection', value: 'keep-alive' },
    'x-amzn-waf-action' => { name: 'x-amzn-waf-action', value: 'challenge' },
    'cache-control' => { name: 'Cache-Control', value: 'no-store, max-age=0' },
    'content-type' => { name: 'Content-Type', value: 'text/html; charset=UTF-8' },
    'x-cache' => { name: 'X-Cache', value: 'Error from cloudfront' },
    'via' => {
      value: '1.1 6752f2850d05a4fdd1d6e5786f5d2938.cloudfront.net (CloudFront)'
    'x-amz-cf-pop' => { name: 'X-Amz-Cf-Pop', value: 'SOF50-C1' },
    'alt-svc' => { name: 'Alt-Svc', value: 'h3=":443"; ma=86400' },
    'x-amz-cf-id' => {
      value: '...'
    'strict-transport-security' => {
      value: 'max-age=31536000; includeSubDomains; preload'
AWS website suggests that ‘x-amzn-waf-action’ header is sent when a challenge for «legitimate client session» is required.
Mar 26, 2024 11:33 AM UTC
Yep we got the same response header
Mar 26, 2024 12:58 PM UTC
Same here.
AWS says it is “Missing, invalid, or expired token”, but token is correct. Creating new token changes nothing
Mar 26, 2024 1:01 PM UTC
Making request with curl works. Using js fetch does not. Maybe it is something to do with User-Agent. Investigating…
Mar 26, 2024 1:26 PM UTC
We’re running into the same issues. We’ve written a bunch of tools that call the Figma API with node-fetch and since of today all we get back is a 202.
I can use the same token in postman and it works most of the time. But even then I’ll get back a 202 every now and then by adding or removing the X-Figma-Token:
Mar 26, 2024 1:27 PM UTC
Using node-libcurl also works within nodejs, but node-fetch or node:https does not. Changing User-Agent does not help
Eugene_Gromadsky
Mar 26, 2024 1:40 PM UTC
same here. btw, 2 days ago it worked fine. now data: ‘’ 🤦
Mar 26, 2024 1:49 PM UTC
We are using axios to call the endpoint 🤷 and I can confirm what @Eugene_Gromadsky wrote. The first time I discovered the problem was around yesterday afternoon.
Mar 26, 2024 1:51 PM UTC
yep, worked for years for me also until today.
