Jin S Kim
Apr 4, 2025 3:17 AM UTC
Annotations appear on Design mode
If you see the screenshot that I attach, the annotations appear in Design mode. I believe that they should appear only in Dev mode. Please advise how I can fix this situation.
    Nellya
    Power Member
    Apr 4, 2025 6:56 PM UTC
    Are you sure these annotations were added using Annotation tool? The design looks a bit off. Can you select one of them and check if they are visible in the layers panel?
    Jin S Kim
    Jin S KimAuthor
    Apr 5, 2025 1:20 AM UTC
    ​@Nellya Thans for your comment. Yes, these annotations were added using Figma’s Annotation tool. The design is visible in the Layers panel as you can see in the attachment. What do you mean by “The design looks a bit off”? What do you see?
    Nellya
    Power Member
    Apr 5, 2025 6:37 AM UTC
    ​@Nellya What do you mean by “The design looks a bit off”? What do you see?
    Design of Figma annotations looks a little bit different than yours. Can you select one of your annonations and show the full screenshot with layers?
    Jin S Kim
    Jin S KimAuthor
    Apr 6, 2025 9:41 PM UTC
    ​@Nellya Is the screenshot what you asked? It looks the same as what you attached.
    Nellya
    Power Member
    Apr 7, 2025 11:42 AM UTC
    Try this
