After a library swap, swapped components won't update without needing a reset?
  • April 12, 2023
  • 275 views
Josh_Moore
  1. I have two Figma libraries, Library A and Library B.
  2. I swapped my project file from Library A to Library B.
  3. I updated a master component in Library B and pushed the change.
  4. The project file I swapped to Library B detects the update and I confirm that the changes should be applied.
  5. None of the Library B components will update with the new styling unless I reset them.
Is this the expected behavior or did I misconfigure the library swap?
Seems like library swapped components have stylistic overrides that must be removed via a reset before they are able to accept master component updates.
