Maya_Voss
Mar 6, 2022 2:19 AM UTC
Adjusting a gradient after applying a gradient style to an object
Created a gradient style. Applied it to a shape. Now how to adjust the angle?
I know it is possible to edit the style itself. But I am not able to figure out how to edit the gradient in the shape unless I detach that style.
Is there a way to keep the style and edit the gradient angle?
Possible feature request?
Aug 14, 2023 4:14 PM UTC
Same question as above^. How do you even edit a gradient angle in a stye? I can only edit gradient angles from specific objects, not the styles. And as soon as I edit a gradient angle, its connection with the style is broken. Seems pointless to have a gradient style if I can’t edit its angle.
Looks like the only way to apply a non-default angle on a gradient style is to set it on an object prior to adding it as a style. Although I won’t be able to change it from that point on.
Aug 14, 2023 9:00 PM UTC
I think I found the answer to my own question. I need to select an object with that style applied, then click on that style from the right-side panel, then right-click that style from the library that pops up from it, and click edit. This is not intuitive at all…
Chuks_Emmanuel
Feb 13, 2024 12:14 PM UTC
Thanks alot, this works for me
