Feb 14, 2023 8:15 AM UTC
Adding 1px when it's exported
sometimes, I see the situation like image added with 1px when it’s exported
is there any solution for these kind of things?
Nellya
Power Member
Jun 4, 2025 5:00 PM UTC
How do we solve this without access to Design Mode?
You need to ask an editor to fix it, or duplicate the file to your drafts and make the changes in your copy of the file by yourself
Sarah_Shuda
Jun 4, 2025 5:04 PM UTC
I just don’t understand why it matters what the position is if the frame is a set size. Shouldn’t it export at that set frame size every time regardless?
ChasenHorizons
Jul 2, 2025 1:52 AM UTC
I’m dealing with this now and every solution presented isn’t working. I have a frame that is 750 and it’s exporting at 751.
So what fixed it for me was viewing the font in pixel mode - and then realizing there was a subpixel issue with this font. One single pixel on a letter ‘g’ was pushing it to export one pixel off.
Chris Wojcicki
Aug 14, 2025 5:40 PM UTC
I’m having this same issue now along with a few other issues that have started to accompany it. I have my figma snapping to pixels, I also have tried the solutions here recommended and I still get 1 pixel added to files. Plus, there’s also a 1 pixel white line around some files too even when the frame defines the background color. The issue isn’t so much that Figma is adding a pixel, the issue is that when my client uploads files to Google ads or for display ads, they need to be PIXEL PERFECT in order to upload! When my team and even some production agency partners are exporting hundreds of ads, you could imagine how difficult and time consuming that can be to check each one when it happens just once.
Feels like this is not something that should be happening at all.
Bexxxx
Sep 19, 2025 8:36 PM UTC
Anyone find solves recently? Seems like a bug. This keeps happening to me with X and Y values set to whole numbers, objects are set to whole numbers and clip content is checked. Object height determined by auto layout but it says they are whole numbers when I hover over hug. Figma is adding 1 pixel in height for 1x exports and 2 pixels for 2x exports.
Sam_Varg
Sep 29, 2025 8:15 PM UTC
It's a bug, use the "Pixel Perfect" plugin to fix it
Tina Wei
Oct 13, 2025 4:00 AM UTC
Maybe the container frame needs an even number width? Not sure whether it will help.
Lucas Rabello
Oct 26, 2025 7:01 PM UTC
If its rotation, turn to zero and then back
I had all of my frames with 90 degrees of rotation. I change it to 0 (zero) and then again to 90 and the bug went off.
Geon_Tavares
Nov 1, 2025 12:58 PM UTC
Perfect! My frames for some reason was with 90 degrees of rotation. After removing it the bug went off.
