offcolor
Jul 9, 2023 9:01 PM UTC
Activated FontBase Fonts Not showing Up
My activated fonts in FontBase aren’t showing up in Figma. They show up in every other app, though. And if I install them directly, they show up fine. That said, I’d very much prefer continuing to use FontBase.
I’m using the most recent desktop app on Windows 11.
I’ve tried:
  • Changing my root folder to “C:/FontBase” from FontBase settings
  • Uninstalling and reinstalling both Figma and FontBase
  • Installing the beta build of Figma
Any ideas?
Ben_Rosati
Jul 10, 2023 3:30 PM UTC
Same problem. Mac M1 Ventura 13.4.1.
Calling it now — Adobe is going to force all fonts to be through Creative Cloud Font Manager
offcolor
offcolorAuthor
Jul 10, 2023 6:42 PM UTC
I fixed it by updating Windows to a developmental build. So it’ll probably be sorted in the next official update.
Maybe doing a similar process on Mac will work for you?
Sajid_Khallow
Jul 13, 2023 5:30 AM UTC
Can you explain it in details how you fixed it? I am having the exact same issue as you!
I am also on windows 11 latest build.
Yotas
Aug 8, 2023 2:09 PM UTC
I think I have found a solution (at least from my end), just set the root folder to this path “%localappdata%\Microsoft\Windows\Fonts”, now it should show fonts in Figma, and it still works for other apps (Affinity, Illustrator, Word, ect), I have installed FontBase as administrator.
Firefox 116.0.2 with Ublock Origin
Figma desktop application
Edition: Windows 11 Pro
Version: 22H2
Build: 22621.2070
Thompson
Jan 18, 2024 7:32 PM UTC
Anyone have any solutions for mac? I’m running Sonoma and activated FontBase fonts aren’t showing up.
Jan 23, 2024 5:45 AM UTC
Hi there, I totally get how it would be beneficial if third-party font managers like FontBase were seamlessly integrated with Figma.
As a workaround, could you give our suggested steps a shot?
You can find them detailed in our help center here: https://help.figma.com/hc/en-us/articles/360039956894-Add-a-font-to-Figma-design
Would you mind giving these steps a go and checking if it resolves the issue for you? I appreciate your understanding and look forward to hearing from you soon!
Thank you,
Feb 12, 2024 8:45 PM UTC
Ok, so I seem to have stumbled on a solution for me. For some reason, the “installed by you” tab in the font selector always appears empty. The installed font appears in the “all fonts” tab. It’s odd that it appears in the “all fonts” tab since the installed fonts aren’t system fonts.
When Font Base activates fonts, it creates a shortcut to the font in C:/Windows/Fonts. Figma displays those activated fonts in the “All fonts” tab.
On Windows, it would be better if fonts detected in the C:/Windows/Fonts appeared in the “installed by you folder” since those are local fonts and not Figma/cloud fonts. On Mac, user-installed fonts appear fine in the “installed by you” tab. Don’t know why it doesn’t work the same way on Windows 11.
adrial
Apr 1, 2024 10:10 PM UTC
I’ve been having the same issue and it’s quite annoying! Fontbase is showing that the fonts are installed, and I’ve even quit Figma and then my machine and Figma was still not recognizing the fonts. Then after I quit Figma, I deactivated then reactivated the fonts in Fontbase, then opened Figma and then Figma was able to see the fonts. Annoying, but at least this worked this time. Good luck, all!
Apr 19, 2024 2:15 PM UTC
We wanted to use Fontbase in my team linked with a GDrive … But Figma just ignoring activated font … no solution work for us here.
Please Figma do something about it 🙏
Brandon_Martin
Sep 5, 2024 6:06 PM UTC
I just ran into this same issue and what you described works like a charm. Thank you!
