Travis2
April 10, 2026
Accidentally published whole library, can I undo?
I have dozens of ‘modified’ existing components in a design library that are in various states of progress. When I went to publish just two of them, I didn’t realize they were all selected - I published the entire library. I worry that if people accept the updates to these unfinished components they may break.
Can I undo this?
Hi ​@Travis2,
I understand you want to unpublish some components you accidentally published.
While there isn't a direct "undo" button, you can try hiding the components and then publishing the library again.
Here are two ways to hide a component in your library file:
  • Right-click the component on the asset in the library modal and select “Hide when publishing”.
  • In the Layers panel, rename the component by adding a period . to the beginning of its name.
After you've hidden all the unfinished components, publish the library again.
You can find more details in the "Hide a component" section of Figma's official guide:
Hide styles, components, and variables when publishing
