mrnb
February 18, 2022
Access/Change "Selection Colors" via Plugin API
Hi community,
i have a question regarding “selection colors”. Is it possible to access and change the colors of figma.currentPage.selection[0] in order to change all occasions of “color x” to “color y” with one change?
So I don’t need to access every single child element and change its color there.
Thanks in advance 🙂
tank666
tank666Solution
July 26, 2023
Now it’s possible.
figma.getSelectionColors()
figma.com – 21 Jun 23
Power Member
February 18, 2022
You can’t access all colors directly like this: selection colors is a high-level feature while the API exposes mostly low-level building blocks which you can use to customize anything pretty much. I don’t see a problem in iterating over all children using something like figma.currentPage.selection[0].findAll and writing a couple of conditions inside of it.
mrnb
mrnbAuthor
February 18, 2022
Yes, you’re right. Could achieve it with findAll(((child) => child.type === ‘INSTANCE’ || child.type === ‘TEXT’|| …)
and
if ( fillStyleId === myStyle.id) { // switch colors }
Works fine for the case.
Thanks 🙂
Power Member
February 19, 2022
Yeah, if you need only certain types of nodes, if you had access to selection colors this wouldn’t have helped anyway, since selection colors show colors from all objects within selection.
mrnb
mrnbAuthor
February 21, 2022
In this case I really wanted to recolor all elements which had a certain color. So “selection colors” would work in this case.
Power Member
February 21, 2022
Oh, I thought you wanted only specific types of nodes judging by this part: child.type === ‘INSTANCE’ || child.type === ‘TEXT’|| … — you don’t need it if you want all nodes.
mrnb
mrnbAuthor
February 21, 2022
but I want all nodes, where I can check for an strokStyleId and fillStyleId to change them. And based on the typescript errors I get, I need to check for certain types of nodes. Don’t I?
Power Member
February 21, 2022
Ah, for that yes. Or you can do this, not as clean but gets the job done:
if ('fillStyleId' in node) {
  // use node.fillStyleId
mrnb
mrnbAuthor
February 21, 2022
Nice, never thought about that. But is it inefficient because it iterates over every single element? Or doesn’t it impact that?
Power Member
February 21, 2022
No, it simply checks if a property exists on an object. findAll iterates over every single node.
tank666
tank666Solution
July 26, 2023
