Daria46
Nov 7, 2022 3:57 AM UTC
A problem with shapes, they are not visible
Hi everyone!
I have a problem, the shapes I create are not visible. I tried to copy them, move them in different ways. Nothing helps. Please tell me what should I do and what could be the reason?
SohrabNiroo
Nov 7, 2022 6:01 AM UTC
Are you sure they are not behind you subject?
Hit ] when selected and they come in front
I hope this is your problem, If not share the link for us to see it.
Daria46
Daria46Author
Nov 7, 2022 7:18 AM UTC
Hello! Yes, I’m 100% sure of that. I have more screenshots, where you can see that the figure is not displayed, and not be under another object. But I can’t attach more than 1 file
Daria46
Daria46Author
Nov 7, 2022 7:20 AM UTC
This rectangle here should be purple, but it’s not visible.
I tried to restart the application, the problem is in this file, in others everything works fine
SohrabNiroo
Nov 7, 2022 7:32 AM UTC
Select layer Click on the color and make sure No fill is not selected, Stroke as well
If the problem remains, then it’s a bug or you have a corrupted plugin cause this mess
Screenshot 2022-11-07 105847
Daria46
Daria46Author
Nov 7, 2022 10:13 AM UTC
No, I checked everything, apparently everything really broke in this file.
I guessed to just copy all the contents of this file into a new one, and everything was transferred! Everything works fine in the new file.
Thanks for the reply, I’m glad you wanted to help!
Problems with the shapes 3
SohrabNiroo
Nov 7, 2022 10:17 AM UTC
Your Welcome
I’m glad you found a solution
It’s strange, If possible keep the file and Email @Figma_Support to check it for you.
Maybe its a Bug and need the teams Attention
The support team answers within few days and they are very helpful.
Daria46
Daria46Author
Nov 7, 2022 10:28 AM UTC
Okay, I’ll send a link to the corrupted file to support, it might be a really interesting situation.
Thanks again for your help!
