mr.a
Jun 12, 2026 9:41 AM UTC
A 400 status code error occurs when using the Figma plugin with Claude Code.
API Error: 400 Invalid JSON schema: regex lookaround is not supported. Found at $.properties.fileKey.pattern.
I am using Claude Code with the company's proxy API key to invoke a Figma plugin for frontend development. It was working fine yesterday, but today, calling the Figma plugin triggers the exception shown above.
I’d like to know if anyone has encountered this situation before—is this an issue thrown by the Figma plugin, or is it a problem with the intermediary API key I’m using?
adamsmasher
adamsmasherSolution
Jun 26, 2026 3:58 PM UTC
Hey again, ​@mr.a and ​@Benjamín Mármol! Are you still seeing this error message?
Our team was working on changes on our side to resolve this issue. If you haven’t tried since reporting the issue, can you test again and let me know if you are still getting that response? Thanks!
adamsmasher
Jun 14, 2026 4:30 PM UTC
Hi, ​@mr.a. Thanks for your post! I can see why this is puzzling given it was working before.
So I best know where to take this issue, could you let me know a bit more information:
  • Which specific Figma plugin are you using, and do you know its version?
  • Are you using the official Figma MCP plugin, or a third-party one?
Also, have you been using this daily or had it been a few days since last using it? That’ll help me narrow down when any possible changes were made that could be related to this issue. Thanks so much!
mr.a
mr.aAuthor
Jun 15, 2026 1:10 AM UTC
​@adamsmasher
Got it. I’m using the `figma @ claude-plugins-official` plugin—installed from the Claude Code plugin marketplace—version 2.2.50.
The issue started occurring on the morning of June 15, 2026; prior to that, I had been using it practically every day.
Benjamín Mármol
Jun 15, 2026 7:36 AM UTC
I’m seeing the same issue from OpenCode with an OpenAI-compatible provider.
The Figma MCP server exposes a `fileKey` JSON Schema pattern that uses a negative lookahead:
```json
"pattern": "^(?!undefined$|null$)"
OpenAI-compatible structured output / tool schema validators reject regex lookarounds, so the request fails before any Figma tool is called. In our case, even a simple non-Figma prompt fails as soon as the Figma MCP server is enabled.
Error:
Environment:
- MCP server: https://mcp.figma.com/mcp
- Client: OpenCode
- Provider: OpenAI-compatible API
- Impact: Figma MCP must be disabled entirely, because the schema is sent with every request.
Suggested fix: replace the lookaround with an OpenAI-compatible schema, for example:
  "type": "string",
  "minLength": 1,
  "pattern": "^[A-Za-z0-9_-]+$"
Or remove the regex constraint and validate undefined / null at runtime.
adamsmasher
Jun 18, 2026 3:59 PM UTC
Thanks so much, ​@mr.a and ​@Benjamín Mármol! I’ve taken the details both of you provided and asked internally for more information. I’ll reply again once I’ve heard back with more information. Let me know if anything changes for you as well! Thanks again for posting about this and for your patience.
adamsmasher
adamsmasherSolution
mr.a
mr.aAuthor
Jun 29, 2026 2:17 AM UTC
That error stopped appearing last week, and I’ve been able to use it normally since then. Thank you. ​@adamsmasher
