Hi,
The bug was discussed in 2021 for adding 1 extra pixel on each side over png export still exists.
For example, I have a circle with dimensions 400x400 in Figma and when exported in my Mac folder, it shows 401x401px. Which is not compatible with the device interface I’m working on…
Of course, a possible solution could be to scale the original component in Figma to 399x399, but should we cheat like this? Is this sustainable?
Any advice?
Hi @Ralev.com the cause of the extra pixel is typically related to either the size or position of an element being a decimal point value.
You can either manually change its coordinates or size to the nearest whole pixel from the Properties Panel, or using the Round to Pixel function from the Quick Actions menu.
This happens to me from time to time as well, especially with PNG
Here is my solve
Ensure the desired export frame/object position is exact on the canvas
Set the x & y position to 0
then export & you won’t have + or - any pixels
To speed things up use plugin
Figma
  • Select your desired export
  • quick actions activate plugin
  • x=0,y=0
  • Now export
id also suggest export presets pluginhttps://www.figma.com/community/plugin/933557553455124671/Export-Presets
Hope that helps
This topic was automatically closed after 30 days. New replies are no longer allowed.
