Hi,
I’m having trouble with ‘Constraints and Resizing’ within a component.
When using the component from an external library, it’s constraints aren’t carried over, instead reverting to the standard top and left.
Changing the ‘Constraints and Resizing’ settings in the library file also doesn’t trigger the ‘Publish styles’ option.
It should fixate to this:
But when importing the component from the library, the component is always left aligned and not switching.
Be the first to reply!
