Why are the search results different when searching within the same range through two entrances?
  • June 14, 2024
  • 7 replies
  • 223 views
Gayani_S
  • June 17, 2024
Hey @otto, thank you for reaching out!
I am double checking this with the team, as I was also experiencing different search result.
Also, could you please confirm if you are searching with the same filter (e.g all libraries)?
Thanks in advance!
otto
  • June 19, 2024
Searching for the same libraries, but the search results are different.
Gayani_S
  • June 21, 2024
Hey @otto, thanks for confirming this!
I am still checking this with our team, but it seems like a unexpected behavior. I will get back to you soon. Appreciate your patience in the meantime!
otto
  • June 21, 2024
Can you provide an estimated time for resolution, as this is currently affecting team collaboration
Gayani_S
  • June 21, 2024
Hey @otto, unfortunately I can’t give you a timeframe when this issue is going to be resolved. However, I’ve just forwarded this to the teams and this is going to be investigated. I’ll give you an update soon.
Please let me know if there is anything else I can help with.
otto
  • July 3, 2024
I have been in contact with the support team for some time now, and I feel that you have no ability to solve problems. However, in our communication, I speculate that the inconsistent or incomplete search results might be due to issues with Chinese word segmentation
The test in the figure involves Figma personnel, and while the search results may be the same, the problems exposed are more severe. The search for the same term “文件” yields vastly different results in the component library and within files.
Gayani_S
  • July 10, 2024
Hey @otto, thank you for sharing this with me. I had forwarded this to the teams internally for the team to investigate.
Thank you,
Gayani
