Figma desktop app not working
  • April 3, 2024
  • 21 replies
  • 8508 views
Aryan_Singh1
Why has my Figma desktop app suddenly stopped working over the past week?
I opened the app one morning and to my surprise, the files kept on loading and loading. Even Figma home doesn’t load. Not a single file is loading and once I shift to Figma home, I am unable to shift back to my files.
Attaching screenshots for reference.
It works on the browser but the app isn’t functioning at all. Please help.
Best answer by Vishal_Ramawat
Seems you are using Windows system.
There could be different reasons for it. You’ll have to isolate the issue.
  • Try clearing the Cache, Temp Files.
  • See if your Firewall / AntiVirus is blocking it. Sometimes an existing app too gets blocked.
  • If your system has updated recently, try a fresh install of Figma.
  • Reach out to Figma Support if nothing works.
Vishal_Ramawat
Aryan_Singh1
Thanks Vishal.
Vishal_Ramawat
No problem Aryan, can you let us know which step actually fixed it?
Here’s what worked for me. I think it should work on Windows or Mac
  1. Click the toggle arrow in the top toolbar
  2. Go to Help > Troubleshooting > Clear Cache and Restart
  • June 25, 2024
I had this problem today and this solution worked for me too!
Worked…Thank you Chris!
Rohan_shrestha
How to slove this problem anyone plz not going through from this.
  • November 25, 2024
Hey @Rohan_shrestha , welcome to the community!
As a workaround, please first clear out the desktop app cache.
Then, make sure that you’re completely logged out of Figma in the browser app, restart both your browser and desktop app, and then try logging in again.
If you are still running into issues, please reach out directly to our support team with your Figma email account, and mention the steps you did so they can check in our backend the issue here. Thank you!
Rohan_shrestha
its show like this…
  • November 25, 2024
Thanks for the additional detail! I see you in the backend you have reached out to the support team. For your reference, your ticket number is: #1185104.
(I’ve also shared your screenshot to our internal team. Thanks for your patience in the meantime 🙏 )
Update: Our technical quality specialist is waiting for your response. Please check your inbox!
Syful_islam
  • December 20, 2024
please help me , what can i do,
by this pc am not i able to use Figma ?
  • December 20, 2024
Hey @Syful_islam , yes, you must be running macOS 11 or later to use the Desktop app. You’d need to update your version of macOS here.
And, if you are using Figma in the browser, the minimum browser requirements are:
  • Chrome 99 or later
  • Firefox 101 or later
  • Safari 16 or later
  • Microsoft Edge 121 or later
You can find all the details in this article ‘What are the system requirements for Figma?’:
Figma Learn - Help Center
Sahil_Suri
  • December 27, 2024
This worked for me. Thank you!
emmarichard380
Hi there,
I had a similar issue recently. First, check your internet connection, as Figma needs a stable connection to work properly. If that’s fine, try clearing the app cache or reinstalling the app to ensure it’s updated.
If it still doesn’t work, switching to the browser version might help while troubleshooting.
Hope this helps!
vewixe5479
  • June 7, 2025
Hello everyone, I recently had the problem that my Figma app did not work and every time I pressed the button it did not redirect to the website, the solution was to uninstall Google Chrome and install the Opera browser and it worked. It is the browser that is blocking the redirection of the Figma app to the Figma website.
Chris Allen
  • June 11, 2025
Worked!!!
shashik
  • July 1, 2025
This works for me. Thanks
UNEED
  • October 2, 2025
This worked for me, but the steps changed a little:
  • Click the toggle arrow in the top toolbar.
  • Go to Help > Troubleshooting > Reset Figma and Restart.
  • Log again and this should solve the issue.
Vikasjaat
  • October 9, 2025
Fabian Jaramillo
I'm having the same issue and I've already tried all the suggestions I've seen on this forum. (Resetting Figma and restarting, the key in Terminal.app, etc.) And I still can't link the browser to the app to log in. Does anyone have any other suggestions? Thanks.
Fabian Jaramillo
