Mass Change Property of Multiple Components?
  • April 11, 2023
  • 5 replies
  • 1983 views
Jace
I have 3000 components with these properties in the wrong order. Is there a way I can change the order without having to drag them into place for each component…
Jakob_Schleenvoigt
Also looking for a solution for this!
Jakob_Schleenvoigt
Found a solution! Apply Autolayout to the frame of all components with “Batch AutoLayout” Plugin. Then Stack all frames on top of each other with Griddle and select the variants you want to change (see screenshot). Then use arrowkeys to shift them within the component frame. This changes the default value of the property.
Jakob_Schleenvoigt
(Griddle is also a plugin)
Jace
  • April 18, 2023
Could you link a video, i’m having a hard time understanding what you mean. When trying it doesn’t seem to change the properties.
This is my current setup:
Sean_Sands1
  • March 7, 2025
I too, would like to know if there is a way to do this.
