Figma在自动布局上面添加元素
  • May 25, 2024
  • 108 views
在自动布局上面加元素,都会自动的添加到自动布局里面,有什么方法可以让用户在使用过程中选择是想把元素添加到自动布局里面还是自动布局上面(如弹窗)
  • May 27, 2024
Hey there, thanks for reaching out!
We don’t have anyone on our community team that speaks Chinese, so I’m going to reply in English - hope that’s ok!
An object’s size determines if it’ll be added to the auto layout frame. So if any of the object’s dimensions are larger than its parent frame, it won’t be added to the auto layout.
You can also use the modifier key to bypass Figma’s default behavior and add larger objects to an auto layout. Or, to add objects to a nested auto layout:
  • Mac: ⌘ Command
  • Windows: Ctrl
There are also a couple of ways to remove auto layout:
  • Right-click on the frame and select Remove auto layout
  • In the right sidebar, click the next to Auto layout
More info here:
Figma Learn - Help Center
