Instances not showing in protoype
  • September 12, 2023
  • 735 views
Hi,
I didn’t find any information about this exact problem, and even don’t know if it’s a problem or am I doing something wrong:
If I have main components with their instances in the same frame, when I see the prototype in presentation mode, those instances disappear from the prototype. If, for example, I rename an instance or copy/paste it to the same frame, the instances show again in presentation mode… until I refresh that window (prototype) and the instances disappear again.
I have seen similar problems, but in my case it’s not related to:
  • Instances not being nested in the frame or overlapping duplicated frames.
  • Instances with the same name.
If I remove the main component from the frame and use an instance instead, all the other instances show properly on the prototype.
Is that a normal behavior? (so, can’t main components live together with their instances in the same frame and all show properly in presentation mode?)
Thank you.
Ryan_52
  • Technical Quality Specialist
Hi @Santiago_Staricco sorry to hear this is happening! This definitely seems strange, would you mind reaching out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email,share a short video recreating the issue, include the links to your file, and share it with support-share@figma.com so they can take a closer look.
