Trying to repeate a transition from different screens without have to place the items on each individual screen every time
  • June 30, 2024
  • 80 views
I hope the title makes sense. Going to try to be as clear as possible.
So I have a prototype I am working on. Say there is the main screen, then 3 sub screens. I create the transition going from screen 1 to 3. I had to add the elements from 3 to 1 in order to have them animate in properly. Now, a user can also access screen 3 from screen 2 and 4. But I dont want to have to paste the same elements into those to screens as well, since I already did it once. Is there a way to have that same transition repeat without redoing it over and over?
Hope that was clear. Thanks
ksn
  • July 12, 2024
Hey @Jeremy_Davis - apologies that my message is coming late, but can you provide a screen recording of the behavior you current have, so I can compare it to the description you made in your post?
I’m admittedly unable to visualize what you’re looking for, but seeing your prototype connections should help a bit. If you can’t share the design, let me know and I can get you to support to review in a more secure setting via email.
