Emoji SVG export issues
  • October 11, 2023
  • 1283 views
Vitaly_Babaev
I has the issues when importing emoji in svg format. For some reasons emoji become a pattern within 24 x 24 icon size. Maybe somebody facing this porblem and has some advice how to avoid this problem?
Figma file https://www.figma.com/file/QwVEZ2Z1B4UeZsw02fTyeE/Emoji-issue?type=design&node-id=0%3A1&mode=design&t=MUOZo66NLlEXbEFn-1
Ryan_52
  • Technical Quality Specialist
  • 382 replies
  • October 11, 2023
Hi @Vitaly_Babaev I tested exporting the layer as an SVG from my end here but it exported the emojis correctly without setting them as a pattern them even after reimport. Are you still seeing this issue? Can you maybe try exporting from different browsers and see if that helps?
