Color Variable Defining
  • June 27, 2023
  • 185 views
Is there any way we can import color theme file (Material theme bulider’s DSP file) to variables, its to much time consuming defining each colors 🙃, if there’s no way then there should be one… @Figma_Support
Best answer by atien
Hey @Anuj_Joshi1,
Assuming the colors in your current library file are tied to styles, can you try out the workflow and plugin outlined in this guide and see if this works for you: Backing color styles with variables - YouTube
atien
  • Figmate
  • July 5, 2023
Hey @Anuj_Joshi1,
