No export library button for Figma Make, also can't access import Figma file from Make
  • October 12, 2025
  • 30 replies
  • 1521 views
Ming Chang
as title, I’m trying to use my published library in a Figma Make project, but the export for Figma Make dialog does not pop up. Also when I click Import From Figma in Make, it does nothing. Tried closing the app and reopen but still the same. I’m on a pro education plan. Is this feature available for me? thank you
Best answer by Tom Reem
Thanks for letting us know, ​@Annisa Avrillia! I just checked in with our Engineering team and wanted to share two quick updates:
1) Import from Make button and workflow
Good news here: Our Engineering team has identified the root cause and deployed a fix. Please reload your tab and try again — the Import from Figma option should now work as expected. ✅
2) Export for Make button and workflow
This appears to be a separate issue from the one above. To help our Technical Quality team dig in further, it’d be great if you could share access to the file where this is happening by filling out this secure form.
When you do, please include:
  • a link to the file where you’re seeing the issue
  • Can edit access for support-share@figma.com
  • a short screen recording showing the issue in action.
Thanks so much for your help — it really makes a difference in helping us get to the bottom of things! Please let us know if you notice anything else.
vladgruzinov20
Same
Tom Reem
  • Figmate
  • October 12, 2025
Hi ​@Ming Chang and ​@vladgruzinov20, welcome to the Figma Forum, and thanks for flagging this along with the troubleshooting you’ve already tried!
To make sure we’re on the same page and narrow things down a bit further, could you share a few more details?
  • Have you had a chance to review the steps in this resource: Bring style context from a Figma Design library into Figma Make. If so, at what point in the process do things stop moving forward?
  • Are you running the latest version of the Figma Desktop App (build 125.8.9 or later)?
  • If this happens in the browser version, which browser and version are you using? You can double-check system requirements here.
If you’re still running into trouble importing or exporting after that, our Technical Quality team can take a closer look at the specific file. You can start that process by submitting this secure form and including:
  1. the link to this Forum post for context
  2. a link to the file where this is happening
  3. Can edit access granted to support-share@figma.com
  4. a short screen recording showing the issue in action.
Appreciate you taking the time to help us get more context on this.
Ming Chang
  • October 13, 2025
@Tom Reem yes I’m using build 125.8.9, and here is the popup that I didn’t see while publishing my library.
Tom Reem
  • Figmate
  • October 13, 2025
Thank you for confirming, ​@Ming Chang — really appreciate you surfacing this here. I checked in with our Technical Quality and Product teams, and our Engineering team is actively investigating the issue.
💡 In the meantime, there’s a temporary solution that may help you keep going: Try copying a frame from Figma Design and pasting it directly into the prompt box in Figma Make.
Just a quick heads-up: Importing assets through the Import from Figma modal won’t work until the issue is fully resolved.
We know this impacts your workflow, and we truly appreciate your patience while the team works on a fix. We’ll keep watch and share any new updates here as soon as they’re available.
Annisa Avrillia
got the same issue..
Tom Reem
  • Figmate
  • October 14, 2025
Tom Reem
  • Figmate
  • October 15, 2025
Checking in here ​@Ming Chang to confirm that we’ve received your file share related to the Export for Make issue. Thanks so much for taking the time to send that over. Please keep an eye on the email inbox tied to your Figma account for next steps from our Technical Quality team. For reference, your case number is: 1550409.
digitalBen
  • October 22, 2025
I seem to have the same issue here
Tom Reem
  • Figmate
  • October 30, 2025
Hi ​@digitalBen, thanks for following up here. I took a look and it appears you were able to get this sorted out with our Technical Quality team by the time I reached your post — appreciate you touching base with them as well. 🙏🏻
I also wanted to share one extra clarification after reviewing other potential causes for this question. If you’re part of an Organization or Enterprise account, access to Export for Make depends on whether AI features are enabled at the organization level. If that setting isn’t turned on, you may want to check in with your admin to confirm.
You can find more details here: Manage AI settings and content training for your team or organization → Adjust access to AI across Figma.
Hope this added context helps anyone else who comes across this thread!
JNTHNMLLR
  • October 30, 2025
Same problem here on my end. Would appreciate any heads up.
Gayani_S
  • October 31, 2025
Hey ​@JNTHNMLLR, thank you for reaching out!
If this is happening in the desktop app, could you please confirm that you’re running the latest version (build 125.8.9 or later)? You can also double-check your system compatibility here: Figma System Requirements.
If the issue happens in the browser version, please let us know which browser and version you’re using, that’ll help us narrow it down.
Our Technical Quality team would be happy to take a closer look at what’s going on. You can reach out to them via this form, when reaching out please include:
  • A file link (invite support-share@figma.com with “can edit” access — this won’t affect your billing), and
  • A short screen recording showing what happens when you try to export or import
This will help us get a clearer picture. Thank you for your help!
JNTHNMLLR
  • October 31, 2025
Hi, thanks for your answer.
I’m already in contact with the support. Let’s hope this issue gets resolved quickly.
Regarding your other questions, I’m on the latest build: 125.9.10
Happens also in Safari 26.0.1
Gayani_S
  • November 3, 2025
Hey ​@JNTHNMLLR, thanks so much for the follow-up and for sharing those details. I’ve added this information to your support ticket so our team can review it more closely.
Please don’t hesitate to reach out if there’s anything else I can do to help in the meantime.
SoliHub
  • November 8, 2025
Hi !
Same here, no export to make and even after publishing, no modal to export to Make.
Same on Desktop app (latest update) and Web
Gayani_S
  • November 12, 2025
Hey ​@SoliHub, thanks for flagging this! I’d also recommend here to reach out to our support team via this form
Our Technical Quality team would be happy to take a closer look at what’s going on. When reaching out please include:
  • A file link (invite support-share@figma.com with “can edit” access, this won’t affect your billing)
EKSKEKSK
  • November 14, 2025
Same here, I can’t see the Export for Make button either.
Mecrano
  • January 16, 2026
@Tom Reem Hey folk, I’m getting the same error at my library, this is solved? can you help me please
I have a Edu Plan
Yulia 000
  • January 21, 2026
Same here. Education plan, no Export to Make button. I’ve already submitted a support request.
  • January 21, 2026
Hey ​@Yulia 000 , for Education plan, this is expected.
I replied to you via another thread, please check it when you have a moment. Thank you!
Rob15
  • February 3, 2026
Been trying to figure this out for weeks. Not seeing any of our libraries in Make. Finally realized that the thing that looks like an ad is actually the UI for this. But my button is gray. Why is that?
EmH
  • February 4, 2026
I’m having the same issue. The export button is greyed out. Hope solution will be available soon.
  • February 5, 2026
Hi ​@Rob15 and ​@EmH, thanks for chiming in here!
I understand how this must be slowing down your workflow. Can you please confirm what plan you’re on?
Most of the users with this issue above were on an EDU plan. If you’re not an EDU plan user, the button might still be grayed out due to your specific AI permissions on the file, depending on the team that the file is within. While we’re not able to assist with Account management here on the forum, if you’re not able to determine the cause with this information, please let me know. I can create a ticket on your behalf to have our support team take a closer look.
EmH
  • February 5, 2026
Hello djv, according to my profile in Figma, it says I am on an org plan and have full seat. How do I/ where do I go to check the specific AI permissions on the file?
  • February 5, 2026
Hi ​@EmH, thanks for the additional information!
I’m not sure if there’s a way for you to check this on your end. My team here on the forum isn’t able to assist with File Management, so I’ve created ticket #1729394 on your behalf to connect you with our support team. They can take a closer look on the backend to see what may be causing this issue.
If you have any further questions, please reply to the support team directly via email.
Piotr S.
  • February 10, 2026
Hi, I have the same problem. what can I do?
