Heavy text containers when exporting to pdf
  • July 25, 2024
  • 15 views
momotova.s52
Hello!
I was making a presentation in Figma and was surprised how heavy it was after exporting in PDF. After checking everything and methodically deleting different parts of the content from the slide, I found that the heaviest part was the text! For example, one 1920*1080 slide with several text blocks exports into over 6 Mb PDF.
If I copy everything on a different slide, it weights the same. But if I create a new slide and new text blocks and type that text manually all over again - the PDF size drops to about 600 Kb. So the problem is definitely with those text blocks.
Any ideas why is this happening and how to fix it? Retiping the whole thing would be a major pain. It is over 200 slides.
  • Figmate
  • August 21, 2024
Hi @momotova.s52, Thank you for contacting us about this. I value the time you spent troubleshooting and understand your frustration.
Without seeing the file itself, it’s hard for us to pinpoint the exact cause of the problem.
If you’re still experiencing the same issue, I can help submit a ticket to our support team on your behalf. That way, you can share the affected file with them directly for further investigation. If you’d like us to assist with creating a ticket, just let us know.
We also welcome any additional insights or suggestions from our community! Thanks again for reaching out.
