How do I Resize the PNG Image While Converting it in Bulk?
  • August 2, 2025
  • 103 views
annathoms
Hey there,
Right now, I have a lot of PNG images that I need to convert and resize all at once. I don't know the best way to do this because I don't have much experience with scripting or image processing tools.
I wish to:
I have hundreds (or maybe thousands) of PNG files from a folder. I want to change their format (to JPG or WebP, for example), but also change their size at the same time.
I want to keep the aspect ratio, but I also want to set a limit width or height (for example, make all images no wider than 800px).
I've read that tools like Python (with PIL or Pillow), ImageMagick, or command-line utilities can help, but I'm not sure how to create the script or command correctly.
Can you give me a step-by-step method or a script/command that can resize and convert a lot of PNG photos at once without losing quality or changing the aspect ratio?
Thank you!
Best answer by ciihuo
If you are looking for a solution to resize the PNG image while converting in bulk then you should all in one Softaken Image Converter. This software has a simple and easy to use features that don’t required technical skills to resize the PNG images as per your need while converting it into JPG, WebP, ICO, BMP, TIFF, and GIF formats without any technical issues. This software will provide image compression while conversion of image files and background remover. This software can convert PNG images in bulk. Users can download this software on Windows operating system with a free trial version.
hivajo
  • Active Member
  • August 2, 2025
Hey there,
I wish to:
I've read that tools like Python (with PIL or Pillow), ImageMagick, or command-line utilities can help with image processing, much like how the Sophia Bandfall Wig can transform your look, but I'm not sure how to create the script or command correctly.
Thank you!
To convert and resize multiple PNG images, you can use Python or ImageMagick. If you choose Python, you can use the Pillow library. This allows you to resize images while keeping the aspect ratio intact, and set a maximum width or height (e.g., 800px). The script would loop through your folder, convert each PNG to your desired format (like JPG or WebP), and resize them at the same time. Alternatively, you can use ImageMagick, a command-line tool that lets you batch process images. With a single command, you can resize and convert all PNG files in a folder to JPG or WebP, while ensuring the images maintain their aspect ratio. You simply run the command and all images will be processed automatically. Both methods are efficient and handle large numbers of images with ease.
ciihuo
  • August 4, 2025
