How to add a component as child element to another component?
  • July 22, 2025
  • 48 views
yasinkara
I simply drag and drop a component to inside of another component but didn’t work. I can’t add component as a child element to another component.
Ellwood
  • Active Member
  • July 23, 2025
Hi ​@yasinkara ,
I take it you are attempting to do this in the master version of the component you are trying to nest a different component into?
yasinkara
  • July 23, 2025
Hi ​@yasinkara ,
I tried on both master and instance.
Ellwood
  • Active Member
  • July 28, 2025
Hi ​@yasinkara ,
You should only be able to do this in the master. Make sure you are in the master component and none of the layers are locked. You should be able to drag and drop another component from your assets list easily.
