Hi everyone, I am trying to set up library thumbnails as components to nest in ‘library preview’ component for documentation so that as I change thumbnail design they sync with the docs.
I am having a problem when i change out the thumbnail component it does not insert as expected. You can see from the screenshot the frame scales as expected but the text does not.
Is this a thumbnail component setup problem or a libray preview thumbnail setup problem?
Thank you,
Mark
Be the first to reply!
