Hover State on Stacked Sticky Layers
  • June 24, 2025
  • 62 views
Mika Bertram
Hey there, im trying to fix a bug in my current Portfolio preparation.
Ive used several frames that stay sticky at the top boarder and stack up on top of each other. However one components of the bottom layers stays clickable when hovering on that exact area of the frame even when it´s covered by the upper layers.
I'll attach a short video to showcase the problem, you can find it via this retransfer link for the next 3 days
https://we.tl/t-XyGD6vKI3O
i hope somebody has a solution many many thanks already :)
Best answer by Junko3
Hi ​@Mika Bertram
I understand you're seeing a situation where an underlying object remains interactive even when it's covered by another object.
This is actually by design. It's set up this way to ensure that frames or elements without interactions don't accidentally block interactions on elements beneath them.
I'm not entirely sure how you've set up your specific prototype, so I can't confirm if this applies directly to your situation.
However, our teammate Toku shared a workaround with sample file for a similar issue in the post below, and it even includes a sample file to help you out! You might find some helpful tips there:
  • Figmate
  • June 26, 2025
Hi ​@Mika Bertram
