Cannot find/access Dev Mode / Design Mode / Ask to Edit
  • June 11, 2025
  • 5 replies
  • 130 views
vld1
Hi, can anyone tell me what do I need to access Design/Dev Mode/whatever on a Figma link in order to export images from a Figma prototype?
I used to have an option to go to Design Mode or Dev Mode or Ask to Edit, but not anymore, something changed and I have no idea what and how.
This is all very confusing and not having an option inside the preview is just bad UX .
Best answer by giliard
Might be a permissions thing, not sure if you're the owner of the file.
Anyway, you can try this to check:
  1. Copy the link of the prototype
  2. Paste it on a browser tab
  3. Change this piece in the link
    1. proto → design
Original (copied link):
https://figma.com/proto/0I5ivEL5fQuABREb7qBDgk/Segmented-Control-Using-Variables?t=e6dmO1x6YcTAzejq-0&scaling=min-zoom&content-scaling=fixed&page-id=0%3A1&node-id=1-11&starting-point-node-id=1%3A11
New link:
https://figma.com/design/0I5ivEL5fQuABREb7qBDgk/Segmented-Control-Using-Variables?t=e6dmO1x6YcTAzejq-0&scaling=min-zoom&content-scaling=fixed&page-id=0%3A1&node-id=1-11&starting-point-node-id=1%3A11
Access it and check if you have permissions to view it.
giliard
  • June 11, 2025
 So, are you not viewing this option while in a prototype?
vld1
  • June 11, 2025
Correct, I used to have that option, not anymore
giliard
  • June 11, 2025
    1. proto → design
New link:
vld1
  • June 11, 2025
Thank you giliard! Your solution took me to a request access page.
It seems the owner didn’t actually grant me the access or there’s some other issue on his side, hope this works.
Bless you for your time & knowledge!
giliard
  • June 11, 2025
You're welcome! Glad I could help.
