Title: "Layout Grid" option is completely missing from the properties panel
  • June 8, 2025
  • 579 views
imyourmeii
Hi everyone,
I'm facing a strange issue where the "Layout Grid" option is completely missing from the right-hand panel.
This happens even when I select a Frame. I've already checked the following:
  • I am selecting a Frame, not a Group or a Section.
  • Auto Layout is turned off (there is no "Layout" section with a minus button).
  • The Frame has zero rotation.
No matter what I do, even creating a brand new Frame with the F key, the "Layout Grid" section simply does not appear. Has anyone experienced this before or knows what might be causing it?
Thanks for your help!
Nellya
  • June 8, 2025
Hi. You need to scroll down a little, the Layout grid is Layout guide now.
