Iterate styles with figma make and figma design
  • June 6, 2025
  • 6 replies
  • 373 views
sileleo
Is there a way to iterate something I created with figma make on figma design? I already arrived to a good result but I can not take the results I have to a user flow on a figma design page :(
Best answer by y_toku
Hi ​@sileleo
As giliard mentioned, this is not supported at the moment.
https://help.figma.com/hc/en-us/articles/31722591905559-Figma-Make-FAQs#h_01JVDBBXN1VM0ZYG6K2C5M9G7S
Currently, while you can attach designs to your Figma Make prompts, you can't bring your Figma Make files or the result of your conversations back to Figma Design.
I will pass this feedback onto our internal team.
Thanks for your patience and feedback!
Toku
giliard
  • June 7, 2025
Once the generated results in Make are actual code-based, and Figma Design is not actual code but a vectorial environment, I don't believe that would be possible.
I think the only integration that Figma Make has is with the Figma Sites.
  • June 9, 2025
Hi ​@sileleo
Toku
Steven11
  • June 10, 2025
You could publish your Make file and then use the URL in the HTML to Figma plug-in to recreate the page in Figma Design. Not sure if that would work but it could. 🙏🏼
Georges_Gomes
  • June 13, 2025
Hi!
We added native support to the html.to.design Chrome extension.
You can transfer any Figma Make result into Figma Design
Blog post about it: https://html.to.design/blog/from-figma-make-to-figma-design
Enjoy!
Lilsab
  • July 10, 2025
Hi!
Enjoy!
Ugh thank you. I’ve been trying to find a solution to this too.
Matt W-P
  • July 29, 2025
Might not be what you’re looking for - but if it’s just to - in order to express the info architecture and move the conversation on, we created a simple ‘screenshot’ explosion from our figma make prototype in figjam - then added link connector linkages. This enabled us to review flows, etc.- quick n dirty hack.
