How to get the non-www version of my site to go to my Figma Site?
  • June 3, 2025
  • 153 views
Sasha Shtern
I just setup my first site in figma sites. I’m using godaddy for registrar and DNS.
www.site_name.com works perfectly
https://site_name.com does not direct to the figma site
How do I set things up so that both the www and not-www point to figma?
Best answer by djv
Hey All, thank you for your patience!
Just an update for you both - Figma Sites now supports apex domains and custom subdomains, so you now have more options for personalizing your URL.
  • Apex domain: Connect root domains (like example.com) to your Figma Site, with optional redirects between apex domains and www subdomains.
  • Custom subdomain: Personalize your URL like yourname.figma.site and make it easier to integrate with any existing domains.
You can learn more about setting up your new domains in Figma Sites here.
Maxim Vetrov
  • June 4, 2025
Same problem.
If i try to use https:// link it gives me DNS_PROBE_FINISHED_NXDOMAIN error.
  • June 13, 2025
Hey All, thanks for reaching out!
Right now, Figma Sites does not support apex domains, but the team is already actively working on it.
As a workaround, you can add a redirect (from non-www to www). Depending on where your domain is hosted, some will offer redirects or the ability to create a custom configuration.
  • July 9, 2025
