How Do You Make a Circular / Ring Slider?
  • May 29, 2025
  • 115 views
AMForlenza
Hi! Industrial Designer turned UX Designer now.
Is there a way to make a circular/ring slider in Figma? I see many tutorials for automatic/animated progress rings but I can’t seem to find how to make an actual user-controlled ring slider. I am also not referring to a linear/bar slider - however, this circle slider would interact just like a bar slider but move in a circle.
Attached here, you’ll see what I’m referring to. For instance, you see these slider rings in various apps where you can set the time, temperature or some other kind of parameter with your finger by dragging the length of the highlighted circle/ring.
Any help or direction to a tutorial showing this is much appreciated!!
