Figma Interactive Component Not Working After Copying to Another File
  • May 26, 2025
  • 6 replies
  • 95 views
Neds
I've created a simple interactive component. A dropdown that's closed by default, opens on click, and should close again when clicked a second time. It works as expected within the same Figma file where I built it, but when I copy it into another Figma file, in to a frame, only part of the interaction works: the dropdown opens on click, but it doesn’t close on the second click.
If anyone has any insight or suggestions, I'd really appreciate the help!
Ondrej_Pavlicek
Hi there!
Thanks for describing the issue so clearly.
Would it be possible to share a screenshot of the prototype settings for your interactive component?
That might help identify where the problem occurs when copying it into another file.
Hope we can figure it out!
Neds
  • May 26, 2025
Sure, Here is an screenshot. Thanks!
Ondrej_Pavlicek
Hi there!
I ran into the same issue recently and found a workaround that seems more reliable. If you connect the interaction directly to the text element, it keeps working even after copying the component into another file.
Hope this helps!
Neds
  • May 27, 2025
Thanks, I will give it a try. But I find it quite disturbing that such an easy interaction still doesn’t work well.
Neds
  • May 27, 2025
I tested it and unfortunately it doesn’t work for me. The drop down opens on click but doesn’t close.
Ondrej_Pavlicek
Sorry it’s still not working as expected. I’ll check again and see if there’s another workaround. I’ll update you if I find anything useful.
