How do I mark a selection as "ready for dev"?
  • May 22, 2025
  • 238 views
Hello everyone! It used to be that I could select a frame or section, and the “mark ready for dev” option would be in the toolbar at the bottom of the screen.
However now I cannot find the option to “mark ready for dev” anywhere in the interface. Where has it gone to? Where is it hiding? Please send help my devs are waiting.
Ondrej_Pavlicek
Hi there!
I can still see the “Mark ready for dev” option when selecting a frame or section.
If it’s missing, you might be in Figma Draw mode – after the last update, some users were switched into it by default. Try changing it back using the bottom toolbar.
Toolbar
Do you have an example screenshot of where you saw it before and where it's missing now?
Hope it helps!
Hello! Thank you for your help. Previously I would click the Dev Mode button in the tool bar, and there would be a toggle right next to it to “Mark as dev”.
As seen in this screenshot, now when I enter Dev Mode, there is no button to “Mark as dev” anymore.
My “Mark as dev”-less toolbar
Where are you seeing the “Mark ready for dev” option on your screen?
Ondrej_Pavlicek
I usually do it from the right-hand panel – in the top right corner of the inspector, there’s an icon to switch to Dev Mode. That’s where the "Mark as ready for dev" option typically shows up.
