Slides Template - Creating/Editing Slide Layouts & Template Styles
  • May 13, 2025
  • 272 views
I created a new Slides template, but I’m still only seeing the default stock slides in the “New slide” dropdown. I’m not sure how to remove those and add my own custom slide layouts.
I’m also unclear on how to create or edit a template style, including setting custom colors and text styles. The deck defaults to the “Light Slides” style, but I don’t see any options to edit or add a new template style.
I’m on a company plan and appear to have full access to Figma Slides.
Any help appreciated.
Jamey
  • July 11, 2025
+1 editing template styles generally feels quite unintuitive
Christopher Roeleveld
Agree – super confusing!
Try publishing your template. This seems to sanitize the file, keeping only the slides you’ve made and the styles within those slides.
A hack I’ve found useful is to make a totally vanilla “starter” template this way. Publish one blank slide, remove all the styles and colors and publish it as a blank starter.
Then, you can dupe that as a starting point for making new templates, without having to wrestle with all the default Figma preset styles and slides. Why this isn’t an option by default is beyond me.
jennifer4
  • December 12, 2025
This might be a stupid question, but can you update a slide that was created from a template automatically by re-publishing changes in the template? Is there any connection whatsoever with the original published template once you use a slide?
I create my own template, works fine,
I build a new deck using one of the slide layouts several times
I go back to my template, change the color and size of a frame and republish,
It seems to have no effect, and i can’t find any UI that links my existing layouts with the new published changes,
I can select to use the updated slide layout for new slides though.
Perhaps I am expecting a PowerPoint interaction and it doesn’t work that way in Figma...help? ;)
I am able to select a slide that I customized from my template.
