Images does not appear in figma after Importing figfile
  • May 13, 2025
  • 4 replies
  • 243 views
Marco van Luyk
After importing a figma file in figma the images do not appear in the design.
I have received the the figma files from the UI designer.
sedatcakir
  • Active Member
  • May 13, 2025
Hello Marco,
This is usually due to the images being added as links, not embeds. When you import images added with external links into a file in Figma, if that link is broken or access is restricted, the images will not be visible.
Michael Phillips
This can happen if the original images were linked instead of embedded. When a .fig file is exported and imported again, linked images often don’t carry over correctly.
It’s a good idea to check with the UI designer and ask if they can re-export the file with all images embedded, or alternatively share the image assets separately so you can relink them manually in Figma. Also, if you're ever in need of UI/UX support or looking for help with design consistency, https://ideamaker.agency/ui-ux/ might be worth a look.
Sam008001
  • May 14, 2025
Hey ​@Marco van Luyk ,
When images do not appear after importing a Figma file received from your UI designer, it is often due to how the images were embedded or referenced in the original file. Sometimes, images are not fully embedded in the .fig file, and instead are linked or provided separately, which means you may need to relink or manually import them into your Figma project. If your designer sent a separate folder with image files that are not standard formats (like PNG or JPEG), you may need to clarify with them how these assets should be used or converted.
Additionally, image loading issues can occur due to caching problems or slow asset loading. Try leaving the file open for a few minutes to see if the images eventually appear. If not, clearing your Figma app or browser cache may help resolve the issue. On a Mac, you can clear the Figma desktop app cache via the Help menu under Troubleshooting, or manually via Terminal. On Windows, close the app and delete the relevant folders in %APPDATA%\Figma. If these steps do not work, you may need to manually import images using the "Place Image" option in Figma (File > Place Image or Shift + Command + K), or by copying and pasting images directly into your file.
I hope it resolves your issue.
AMR ADEL
  • November 1, 2025
Hello
I am writing to report an issue I am experiencing while using the tkinter-designer tool to convert a Figma design.
When I run the conversion process using my Figma file URL and API token, the tool appears to generate the Python code successfully. However, the resulting Tkinter application is effectively empty because none of the PNG images (assets) from the Figma file are being downloaded or referenced.
Summary of the Problem:
  • Tool: tkinter-designer
  • Input: A Figma file URL and a valid API Token.
  • Expected Result: A Python GUI application with all layout elements and a corresponding assets folder containing the PNG images from the Figma design.
  • Actual Result: The Python code is generated, but the assets folder is either empty or the images are not included, causing the GUI to render without any images.
I have already verified the following troubleshooting steps:
  1. The Figma file sharing permission is set to "Anyone with the link can view."
  2. My Figma API Token is correct and active.
  3. The images within the Figma design are standard PNGs and are correctly named.
Could you please provide any guidance on what might be causing this issue? Is there a specific setting in Figma or a particular step I might be missing to ensure the image assets are properly exported and included?
Thank you for your time and assistance.
Best regards,
