Text change issues with nested instances
  • April 23, 2025
  • 26 views
maskar
I have the following component that consists of a Text, 2 nested toggle instances and 3 nested input instances.
When you click between the toggles, the input lable text changes/variation change.
This works if I only have one instance of this componet, but when I hav multiplle instances of this component in the same frame, the first nested input field dosen’t change its label text in prototype mode. However, it works if I manually change the variant through the Design panel.
Here is how it looks in prototype mode:
Everything looks good
Oh no, the first nested input instance in the first instance don’t change as it do in the second instance.
used the add button (+ Tilføj ejer) to add a third instance. The seocond and thid instanc elooks fine.
Trying to toggle the second instance, but oh no, now the first nested input instance in the second instance don’t change either. It only works as intended in the third instacne.
What is going on? Whelp!?
