There's a problem with the constraints inside a component
  • March 10, 2025
  • 42 views
Catalin Rusu
Hello. There seems to be a problem with the constraints of components. Seems like one part of the document is ok and the other not. I’ve tried everything from duplicating the document, copying to another page, etc
The only thing that worked is that I moved everything on the page to the left, but everything beyond the point in the video does not work. It’s bugging out.
Because of this bug, I cannot create more variations.
Please help me fix this. It’s driving me crazy. Thank you in advance.
https://www.loom.com/share/af8f8d2d8c674f2e9078185d8465c713?sid=97414fec-537a-4845-8016-f4f0ee79ee41
Catalin Rusu
  • March 10, 2025
Just found out something. When the variants are withing the -35000 and 33350 ruler marks, they work, but anything past that, the content bugs out.
Catalin Rusu
  • March 10, 2025
After some more testing. It seems like it’s a grid problem, not a component problem. This only happens with grids that are stretched with no margin and no gutter. When I remove the grid, the constraints do not apply anymore.
Catalin Rusu
  • March 10, 2025
I’ve managed to fix it. All I had to do was select all frames inside and select scale constraints. Now the problem si gone. Hope this helps someone.
