Would swapping libraries in a branch merge correctly in the main file?
  • March 7, 2025
  • 32 views
Yara_Farhat3
Hello,
we got a libraries from another team and it’s imported in our company’s folder. The new libraries has new components and styles (dark mode) so I need to swap the old library with the new one.
I created a new branch to avoid ruining the main file and I am planing on merging it when I finish the dark mode library swap and mockups.
Any idea if this will work?
vishwakarmayojana
Yes, it should work as long as there are no conflicts in dependencies or component structure. Before merging:
  1. Test thoroughly in your branch.
  2. Check for breaking changes in components.
  3. Ensure styles don’t override existing ones in unexpected ways.
If needed, use feature flags or a staging environment before merging to the main branch.
