Is it possible to copy frame along with the dev mode annotations?
  • March 6, 2025
  • 117 views
Lee Yunkyu
Hello. I am looking for a way to copy frames with dozens of annotations attached to them into another file as they are. With regular copying, there's no way to copy the annotations along with the frame, so I have to manually copy them all.
Best answer by Phu_Nguyen
Can you recreate your problem with a screen recording?
I have tried both duplicating frame in the same file, and pasting in other file. They both keep all the annotations and measurements.
It is fun that when I find posts related to annotations, I see these posts next to each other in a same page:
Phu_Nguyen
  • Active Member
  • April 1, 2025
Lee Yunkyu
  • April 1, 2025
I also forgot why I asked this question.
I remember that It occurs when I didn't select the inner frame with the annotation and selected the outer frame, or pasted the frame into an external file.
But it looks like neither of those is the case.
Phu_Nguyen
  • Active Member
  • April 1, 2025
Or maybe they had a release for that case just after when you asked.
