Figma Plugin Manifest Error: Invalid Permission & Unexpected Token in Code.js and not working
  • February 28, 2025
  • 26 views
Aditi996
as i am trying to build a plugin but i am getting multiple error i need help
https://github.com/aditya-sphereoutsourcing/figma-htmlui
manifest error
```[MultiplayerSession] connecting to wss://www.figma.com/api/multiplayer/skAAAf7VyQmRisgj13EAP8?role=editor&tracking_session_id=7rHTmiATEjOrmCbe&version=132&recentReload=0&file-load-streaming-compression&user-id=1152675224738433395&client_release=ec4382e63ff24ce1638430575c5ae5984142263a&clientID=d81ea5e1344845d08ab3e9592a1acc93
vendor-core-c0e306375f090f60.min.js.br:77 [MultiplayerSession] Joining file version 70 (full reconnect)
vendor-core-c0e306375f090f60.min.js.br:77 afterJoinEnd PageSyncing: Loaded incrementally Object
vendor-core-c0e306375f090f60.min.js.br:77 Manifest error: Invalid permission specified: currentPage
(anonymous) @ vendor-core-c0e306375f090f60.min.js.br:77
6vendor-core-c0e306375f090f60.min.js.br:77 [Local fonts] using agent
vendor-core-c0e306375f090f60.min.js.br:77 Manifest error: Invalid value for networkAccess. If you want to allow all domains, please add a "reasoning" field to the networkAccess object.
2vendor-core-c0e306375f090f60.min.js.br:77 [Local fonts] using agent
vendor-core-c0e306375f090f60.min.js.br:77 [jsvm-cpp] main called (emscripten version 2.0.31)
vendor-core-c0e306375f090f60.min.js.br:77 Syntax error on line 52: Unexpected token .
        parsed.textContent = element.textContent?.trim();
K @ 5572-38e0a9711b3c6ccf.min.js.br:427
vendor-core-c0e306375f090f60.min.js.br:77 Error: Syntax error on line 52: Unexpected token .
    at K (5572-38e0a9711b3c6ccf.min.js.br:427:45)
    at async 5572-38e0a9711b3c6ccf.min.js.br:557:9840
(anonymous) @ 5572-38e0a9711b3c6ccf.min.js.br:557
ei @ 5572-38e0a9711b3c6ccf.min.js.br:557
vendor-core-c0e306375f090f60.min.js.br:77 [MultiplayerSession] connecting to wss://www.figma.com/api/multiplayer/skAAAf7VyQmRisgj13EAP8?role=editor&tracking_session_id=7rHTmiATEjOrmCbe&version=132&recentReload=0&file-load-streaming-compression=&scenegraph-queries-initial-nodes=0%3A1&user-id=1152675224738433395&client_release=ec4382e63ff24ce1638430575c5ae5984142263a&clientID=d81ea5e1344845d08ab3e9592a1acc93&reconnect-key=a20eb3618abb4ccacb0d793005e92597ad6fc6df&reconnect-sequence-number=2&initialFileVersion=70&previousLoadMode=incremental&incremental-loading-validation=0
vendor-core-c0e306375f090f60.min.js.br:77 [MultiplayerSession] Joining file version 80 (full reconnect)
vendor-core-c0e306375f090f60.min.js.br:77 Migration succeeded: context: fullscreen_migrate_pending_changes, version: 80, duration: 0ms.
vendor-core-c0e306375f090f60.min.js.br:77 Migration succeeded: context: fullscreen_migrate_pending_changes, version: 77, duration: 0ms.
vendor-core-c0e306375f090f60.min.js.br:77 Migration succeeded: context: fullscreen_migrate_pending_changes, version: 75, duration: 0ms.
4vendor-core-c0e306375f090f60.min.js.br:77 [Local fonts] using agent
vendor-core-c0e306375f090f60.min.js.br:77 [MultiplayerSession] connecting to wss://www.figma.com/api/multiplayer/skAAAf7VyQmRisgj13EAP8?role=editor&tracking_session_id=7rHTmiATEjOrmCbe&version=132&recentReload=0&file-load-streaming-compression=&scenegraph-queries-initial-nodes=0%3A1&user-id=1152675224738433395&client_release=ec4382e63ff24ce1638430575c5ae5984142263a&clientID=d81ea5e1344845d08ab3e9592a1acc93&reconnect-key=a20eb3618abb4ccacb0d793005e92597ad6fc6df&reconnect-sequence-number=3&initialFileVersion=80&previousLoadMode=incremental&incremental-loading-validation=0
vendor-core-c0e306375f090f60.min.js.br:77 [MultiplayerSession] Joining file version 80 (skip_reload reconnect)
2vendor-core-c0e306375f090f60.min.js.br:77 Error: Syntax error on line 52: Unexpected token .
    at async 5572-38e0a9711b3c6ccf.min.js.br:557:9840```
