autolayout hugging layer that is turned off
  • February 26, 2025
  • 18 views
Melissa Rossi
I've set properties on the component to turn off the label and helper text, but when turned off, the layout still hugs the space where the text would have been. Is there a way to avoid this?
Below is the main component, and the instance on the right shows the text turned off but still affecting the spacing.
Raphael_M
  • February 27, 2025
Did you just set the opacity to 0? Because you have to hide them in the layer
