Advanced Prototyping: adress multiple states of instances
  • February 23, 2025
  • 18 views
Stephan Bayer
Good Morning Community.
I have a problem with advanced prototyping. It may have been solved at this forum but I wasn’t able to find any hints yet.
Within the following dropbox link you’ll find 3 images: https://www.dropbox.com/scl/fo/3w3i3ftsms8vf29b19jui/AHMy0ofKB341QQkWHQ9QErU?rlkey=pfvyb14qt4zuq63aocn2ltmm5&st=abwrji4b&dl=0
Starting with image 01:
This page is the project overview. When the user enters this subpage, the first project should be at active/hover state and the images shown below should be linked to this project. After hovering project 02, this one changes to active/hover state and the images below are updated.
Image 02 and 03 are my current interactions linked to every project.
The problem is, that I want the active/hover state ONLY to be changed (&& the images to be updated) when the mouse enters a new project and NOT when the mouse leaves one project (for example to the whitespace above). That means the last hovered project should stay active as long as the user hovers another project.
I hope you guys understand my problem and can help to find a solution.
Cheers,
Steve
