getVariableByIdAsync got error when the variable (color) is not used in the file
  • February 12, 2025
  • 45 views
Toshiyuki_Hayashi
Hello,
I’m using getVariableByIdAsync API to get a variable info. For example, I try to load a color variable which key is VariableID:d2c9451722738c45a0c75047e467b459856cce94/49352:54
The code will be:
const iconTertiaryVariable = await figma.variables.getVariableByIdAsync(
"VariableID:d2c9451722738c83a0c75047e467b459865cce94/49352:173"
If I use the color variable in the figma file already in another element, it works. But If I haven’t used the variable yet in the file, I got error always. It says:
The variable with id "xxxxxxxx" does not exist.
How I can load the variable without this error?
Toshi
tank666
  • February 13, 2025
See answer here:
Also similar topic:
Toshiyuki_Hayashi
@tank666 Thank you!! That’s exactly I was looking for. You made my day.
