How to display a "Hover" State on Multiple Cells within same Column
  • January 22, 2025
  • 27 views
javaria.c
I am having an issue where if you have a table layout with each cell containing a component with a “hover” state showing a pop up, the top most layer works just fine but anything below it, shows the layer set to “first” or up front within the layers panel. I need the hover to work for all if possible. If not, I will have to only showcase one field working in this manner for the prototype.
Any help would be greatly appreciated!
Top most layer hover card:
Second hover card where the top most layer appears up front.
Thanks!
