Exports adding a thin white line top and bottom
  • November 16, 2023
  • 23 replies
  • 6214 views
Hi all,
When i’m exporting to a JPG with a dark background, the export is adding 1px to its original size which then creates a thin white line top and bottom
  • November 16, 2023
Hey there, thanks for reaching out and sorry for the trouble!
This is a bug for decimal exports that our team is aware of. These white lines appear when exporting a JPG that is positioned on a sub pixel value (i.e. any value with a decimal point). To prevent this from happening, ensure that the width, height, and/or X and Y positions are on full integer values before exporting.
Etienne4
  • June 26, 2024
Sorry this is not a sollution for me. The widht is 500px height 100px And the X and Y are 100. Also all the elements within the image have a integer value
Josh
  • Former Community Manager
  • June 26, 2024
Curious if this changes depending on what file type you export? If not I would file a bug report via the following form https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374&tf_1500005293441=generic_report
Jessica_Banda
I’m having this problem as well. All elements are also within full integer values yet when I export the white border still appears.
Etienne4
  • August 18, 2024
My solution was to unckeck “clip content”. Hope it will work for you to. 🙂
Jessica_Banda
Update: My solution was to remove/correct a drop shadow effect on an element within the frame that extended outside of the frame. I assumed the export would only show everything within a frame and not support any element outside of it. Hope this helps.
ansbari
  • September 25, 2024
My issue was resolved by going through each section (of the whole page) one by one and there was a section having height of 880.17px. Once I adjusted the height to an integer it got solved.
Samuel_Anthony
If this isn’t fixed, still to this day, then why is there a thread that’s been closed and marked as “fixed” by you when it is still very much a bug we all face - that thread was from 2021???
Ian_Palmgren
  • Active Member
  • December 19, 2024
Still not fixed, Dec 19 2024. This has been an issue since the day we started using Figma in 2019. Sure would have hoped to have seen this addressed by now…
Qasim
  • December 30, 2024
Not any of these solutions working for me.
Florin Potor
  • March 3, 2025
I had the same problem, here’s how i resolved it:
Create a new frame with the desired size (exactly what you need, not +/- px). Then, you can copy-paste the graphics from the frame that has the export error to the newly created frame, just don’t copy-paste the whole frame. I noticed if you copy-paste / duplicate the frames is when the exported error happens, be it with one line top, bottom, two lines on the sides, etc. Double check in the preview area, and export.
I started having this problem when i was duplicating frames in order to change titles, and nothing else helped me.
Hope this will help, even though its been months since you posted.
Cheers,
Florin
MichaelS
  • March 22, 2025
Seems like the bug is still out there. Social posts are literally live right now with white lines in carousels for several clients.
We’ve used the ‘Fill’ option to fill the carousel artboards with images. In Figma it seems alright.
In Photoshop you can see a transparant line..
Ian_Palmgren
  • Active Member
  • March 25, 2025
Hey ​@dvaliao, can you please unmark this is as “Solved”? While forcing exact integers is a workaround, the issue is still not solved. Figma should round down, when sub-pixel levels are detected, not round up, which results in the white lines, that is the solve here. We shouldn’t have to check every single X, Y and W/H coordinate every single time we export to ensure frames are exactly on integer pixel levels.
ca-sey
  • April 2, 2025
@dvaliao You’re aware of the issue and you still haven’t solved it? Instead, you just throw in a ‘solution’ that only worked for like one person and proceeded to close the thread? Do you know how annoying this bug is and how many people it probably affects, and you’re sweeping it under the rug??
As user Ian_Palmgren said, and I quote, “please unmark this is as “Solved”? While forcing exact integers is a workaround, the issue is still not solved. Figma should round down”. I’ll repeat it once more for you, bolded, “Figma should round down, when sub-pixel levels are detected, not round up, which results in the white lines, that is the solve here.”
PLEASE help us. PLEASE.
Kaylee Lee
  • April 15, 2025
Helllllo—still having this issue. I work for a large client on social media and we cannot use Figma for our social posts anymore. Super disheartening to see what seems like a simple issue not being resolved (and quite frankly ignored).
MichaelS
  • April 18, 2025
Especially with allot of users using Dark Mode right now the lines are even more visible than ever. We’ve had Paid Ads running with white lines 😭
Temporary solution: There are Figma Plugin that fixes this Figma bug, they’re called Clean Document and PIxel Perfect. They fix your artboards’ X and Y’s to full numbers. This solved it for our clients.
MichaelS
  • April 18, 2025
And for what reason would a user want to place an artboard on X 0.5 and Y 0.5 anyway? Can we fix this in an update asap to full numbers? X1 Y1, X2 Y2 etc.
Ian_Palmgren
  • Active Member
  • May 14, 2025
@dvaliao this issue is plaguing us on a daily basis and impacting business work. An acknowledgement that that is still a known bug, and removing the “Solved” status on this thread would go a long ways in helping us feel like the community is being heard and valued.
Kaylee Lee
  • May 14, 2025
The amount of work I’ve been able to do in Figma has reduced significantly. One solve is to download (and unfortunately pay for) the SCRL app. All the workarounds above still do not work.
kfische4
  • June 11, 2025
Hi there! I think I’ve found a simple solution to this issue. I used the crop tool to extend the image box by one pixel in all directions, and that seemed to resolve the problem.
At first, I only extended the side where the line was appearing, but that didn’t help. Then I tried extending the opposite side, and that did the trick. My theory is that the opposite edge is wrapping around by one pixel, which causes the line to appear.
Kaylee Lee
  • June 11, 2025
Hmm, I wonder if this is a good solve for continuous carousel frames that can’t afford to have a weird crop/split.
kfische4
  • June 11, 2025
True, the image may become one pixel larger, but if that pixel is transparent, you won’t notice it—especially if it’s being overlapped.
In my example, I noticed a line on the right side after exporting. So, I extended the left side by one pixel, and that resolved the issue. Technically, you don’t need to expand all sides—just the side opposite the line.
(The left side of the image before extending was touching the image wall which was probably the culprit)
SomethingFishy
  • Active Member
  • September 8, 2025
As usual, something incredibly rudimentary that should take me 3 seconds has taken me an hour trying everything in this thread and I’ve gotten nowhere. Thanks for the unkillable janky border, Figma.
So every jpeg I export from Figma I’ll also have to run through Photoshop to crop by 1 pixel. Fantastic.
